I used a lian li pc-60B plus II for my 1st build & liked it, that was with a quad core q-9550 cpu.
My next build will be with a i7 920 & am concerned with the cooling capacity of that case ( 2-80mm's & 2 120mm's). It does fine with the quad core but I'm not so sure with the i7.
I've been looking at the lian li PC-K1B or PC-A6010B which both have 1-120mm & 1-140mm.
Does that fan config offer more cooling capacity than the 2-80mm/2-120mm's on the 1st case?
Would 1 120mm & 1 140mm be enough for the i7?
below are my parts excluding case, having a devil of a time deciding on the case.
(i wont be doing dual video cards, maybe mild overclocking)
MOBO=GIGABYTE GA-EX58-UD3R LGA 1366 Intel X58 ATX Intel Motherboard
CPU=Intel Core i7 920 Nehalem 2.66GHz LGA 1366 130W Quad-Core Processor
RAM=mushkin 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model 998691
POWER SUPPLY=CORSAIR CMPSU-620HX 620W ATX12V v2.2 and EPS12V 2.91 SLI Certified CrossFire Ready 80 PLUS Certified Modular
HARD DRIVES=2 ea Western Digital Caviar Black WD1001FALS 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drives
DVD BURNER=2 ea LG DVD Burner Black SATA Model GH22NS50
VIDEO CARD=SAPPHIRE 100277L Radeon HD 4770 512MB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card
