[SOLVED] Stuck on VGA led on MSI B450m pro-vdh
I recently tried to build a budget system but I am stuck and don't know what to do next. Can you please help?
CONFIG
Ryzen 5 1400
Msi b450 pro vdh
Silicon Power 8 GB DDR4 2400Mhz sp008gblfu240bs2
Zotac gtx 1060 6b
Corsair vs550
ISSUE
I am not able to POST. Initially the ez debug led on cpu will blink then led will stay lit on vga, nothing will come up on monitor, even the stock fan on the processor will not power up. I have cleared cmos. I read multiple threads on the problem which asks for updating the bios, but how to update the bios if I can't even boot the system? Also do I need the GPU attached while booting up, There were threads which asked for iGPU but since r5 1400 doesn't have an integrated gpu should a graphic card work? Could it be the issue with RAM does 1400 need ram of higher frequency?
I am totally lost and and going insane someone please help
So, the CPU is supported, so no BIOS issue.
Make sure that all required PCIe power cables are connected to the graphics card and connect the monitor to the card, not to the motherboard.
