Hi guys,
so I build my first PC and I'm having an issue with it. Stuck on white LED(VGA Q-LED)and NO POST. This is the whole thing.
When I finished the installation for the first time, everything was fine and Windows was running normally. But when I was using it the next day, the computer suddenly crashed. When I restarted the computer, No display on monitor, VGA LED solid white, Fans spinning, no weird noises etc. So I tried the following (no help):
Appreciate any help i can get.
System Components Currently Installed:
- reseating the GPU
- reseating the ram (1 only or 2)
- reconnecting the pcie power cable to make sure it wasn't loose
- reconnecting the display port cable to make sure it wasn't loose
- trying a different pcie power cable
- trying a different pci slot
- trying an hdmi cable instead of using display port
- checked for bent/dirty pins
- short the cmos pins to clear the CMOS
- MOBO:ASUS ROG STRIX B550-I GAMING
- CPU: AMD Ryzen 5950X
- RAM: Corsair DDR4 3600 MHz 16GB*2
- Heat Sink: NZXT KraKen Z63
- GPU:ASUS TUF 3070
- PSU: PHANTEKS AMP 1000W
- SSD: Samsung 980pro NVMe M.2
