Question stuterring,lag,fps drops and low fps
Feb 14, 2019
5
I am stuttering and getting lag spikes and fps drops on alot of games like fortnite and apex legends.
can someone please help me fix this problem
specs:
intel core i5 6400 @ 3.2 ghz
gtx 1060 3gb
16 gb ram
cin19
For the game lag, you should check the internet speed, or the game server hosting, so check the speed first https://www.speedtest.net/ or try a different server.
For the fps drop, that related to your PC, like cpu/gpu overheat, and the PC does not have the right drivers, like network, chipset, gpu driver, etc. One more what PSU did you have?
Feb 14, 2019
5
for my psu i have an shp 650 and btw it takes quite a while to boot up my pc so idk if that has anything to do with the lag problem
cin19
If you don't find out what cause the problem first, I think you will waste the money.
So
  1. do you check the cpu/gpu temp during the game?
  2. try remove the gtx1060, use onboard iGPU to see what happens.
  3. Update all the drivers.
4)Check the internet speed, try other server.
