Stuttering issue with no FPS drop.
FrappeDuRocma
Commendable
Dec 9, 2016
8
Hey !
I have a problem when i'm playing a video game, the gameplay is not smooth and i don't know if it's stuttering, because i don't know how to describe it exactly.
Here is a video: https://streamable.com/lg29
My graphic card is a R9 390, my PSU is a new 750 G2, my CPU is an intel I7-4790K, my motherboard is an GA-Z97-D3H.
Thank you and have a nice day !
first, make sure your graphics drivers are updated, if they are correct and updated, proceed
What are the temps of GPU/CPU while running the game?
Please also list me your resource allocation.
I need to know what your CPU usage is under load,
Ram usage is under load (Modified, standby, and FREE),
and your GPU usage under load.
Driver are uptodate.
https://gyazo.com/1a3d265ab47f860509232ca19fd390a9 CPU usage when i'm playing the game.
https://gyazo.com/d4528b01acdd7ed852dd24b545951eb8 CPU usage when no game is running.
https://gyazo.com/bda33a104d34c86cd19facdc116ebcf1 GPU usage while i'm playing.
https://gyazo.com/bffa17ae754a9935ff77133441262e5f GPU when no game is running
https://gyazo.com/83c5ea51ddcef8234bcf98b8a5363725 Memory Usage while i'm playing.
https://gyazo.com/5673880f111673a5d4ccbda8f52c08e6 Memory Usage with no game running.
Thank you.
EDIT: OpenHardwareMonitor report: http://pastebin.com/WkpSR001
Is that playing multiplayer? If so it's network lag most likely, having trouble keeping up with the game.
Play the Game Single player, let me know if you still experience the chop
Those are just temps, I need actual charts and cpu usage on each core and memory I need to see all of it in resource monitor.
Picture: https://gyazo.com/50e1266757a910da348f9413d719c2f2
https://gyazo.com/e720a8a933bff9acfd4f6d5c6043d9fd
https://gyazo.com/dda369ababd2c7548a6196b85ab67846
If it's not good, can you tell me what software can i use to make a proper report please ?
I'll try a solo game and be back.
Thank a lot.
EDIT: Offline the game is smoother unlinke the online one. But when i'm recording it's looks not smooth at all, i tried both CPU and graphic card recording and they both looks the same.
It is your internet most likely, if you are trying to record or stream you will always encounter this error. A suggestion is looking up some guides on doing it.
one of the big reccomendations is having another computer or laptop one of lower power, you put your streaming program on this and you record/stream from this small PC while your computer handles the game. This leads to much better internet results, much less choppy and laggy. Better sync and just better display in the end.
My guess is your choking your internet upload/download. its very easy to bottleneck the upload channel and it will have serious degradation on the entire system.
When playing a game can you do a ping test to google, and a traceroute. We need to check your upload/download and your ping.
Speedtest.net
pingtest.net
Post results
