Hello Guys,
So this is going to be a longer story, sorry for that.
It all started when my 7 year old PC started to stutter in League of Legends.
At this time i had a GTX 1060 in the pc and wanted to upgrade for a long time. So i bought myself a RTX 2060 super. For 2 weeks everything was running smooth but then the same stuttering was happening again.
I was thinking "well, PC is pretty old let's buy a new one".
I choosed the components for the new PC and recieved it pre build by a online service.
For the first weeks everything was running smooth, but then after a few weeks same thing happened, stuttering! Almost only in league of legends.
From there i started to rule out components as the only things that went into the new PC were the RAM, GPU and the Monitor. I bought new Ram a new monitor and the RTX 3070. Still stuttering!
I cant play league of legends with a RTX 3070!! Well. I tried everything now.
Drivers, Reinstall Windows, disable several things in hardware manager, monitoring my whole PC if its running too hot. But nothing.
Everything should be working right.
Today i plugged in my gaming laptop without screen etc and i had the same stuttering!!! I then thought it could be the internet. No package loss. No ping spikes nothing.
Guys, i dont know anymore. Please help me to find a solution. Im mentally done. This PC was so expensive and it didnt solved anything.
Tell me what to do and i provide any necessary info to find the issue.
You are literally my last hope.
SPECS:
Intel i9 - 10900k
32gb ram @ 2666mHz ( 4x8 GB ) ( Crucial Ballistix )
RTX 3070 Zotac Twin Edge OC
z490 vision d gigabyte motherboard
850w Corsair PSU
THINGS I TRIED:
Thank you for the help. Really appreciate it!
SPECS:
Intel i9 - 10900k
850w Corsair PSU
THINGS I TRIED:
- updating driver
- clean booting windows
- power plan settings ( i need to play in balanced mode, otherwise windows overclock my CPU even on idel to 5,2ghz!
- deinstalling several programs known for causing troubles
- different keyboard and mouse
- old monitors
- latency mon / there is latency. i can post more infos if needed.
- why so slow? / bios hat a latency of 800ms !
- RTSS settings, GSYNC settings etc
- reinstall GPU driver several times with DDU
- reinstall league of legends several times
- switched ethernet cables, also tried wlan
- monitoring my hardware, everything seems normal, but im not a pro
