My pc has been stuttering on games and I don’t know why, it mostly happens when I play games like rust. No matter how low I put the settings it stutters. My brother’s pc runs the same games at a steady 10 fps higher and his frames barely drop where as when I look in a different direction my frames will drop from 90 to 40 even though my build has newer/higher end components. This is my build:
Zotac 1070ti mini (overclocked to +150mhz gpu clock and +290mhz memory) gpu
Amd Ryzen 5 1600 (overclocked to 3.8ghz at 1.3125 volts with stock cooler) cpu
G skill Ripjaws ddr4 2x8 2400mhz ram
Asrock ab350 pro4 motherboard
Corsair cx550 power supply
128gb ssd storage
1tb hdd storage
128gb ssd storage
1tb hdd storage
