Stuttering problem ?
distlingur
Hello i have seen many threats about stuttering problems, does anyone have any solution?.... My problem is getting so annoying because it happens so randomly . It seems to be problem with running games/programs. When i play for exsample Battlefield 3 it is most of the time normal play but sometimes usually after an hour play. The sound,mouse and the cpu get stuttering and the only solution is Restarting the computer. I have also notice in some games only the sounds get stuttering. I got ati hd 8700 series card and this famous Realtek hd audio .. Any suggestions?
system specs - edify me about stuttering.
Hey guys! I found this from a separate thread talking about a similar problem. Here is what samking1489 said:
"I had the same problem yesterday and now fixed....just go to control panel then system and device manager. unninstall the wireless card not just disactivating...when done restart your pc and reinstall the card with the last driver you can find on asus website...everything's fine now...very important to uninstall the old drive cause it wont update if you dont.
Hope ist gonna work!"
After struggling with incessant, reoccurring stuttering problems (affected everything: audio, video, mouse, typing, etc.), I applied this simple step and BAM! the problems gone!
A little background for my specific problem:
6+ months I had been dealing with this issue. Initially, I thought it might have been related to other motherboard problems I was having (major crashing) - stuttering problem turned out to be a separate issue altogether.
After trying nearly everything: driver updates (for everything!), resetting bios defaults, updating BIOS (on previous motherboard before RMA), various scans (hard drive, virus, registry), etc.
The simple solution that samking1489 provided above has so far worked like a f***ing charm! :)
The relief of which inspired me to join tomshardware just so I can make this post. Seriously, been browsing for a fix a LONG TIME.
Thanks samking1489!
