Stuttering with high fps and low temps in all games
Niko_18
5
So im looking for and answer for months but i didnt find one . Therefore i want to ask the community. So my problem is that i get weird stuttering although i have way over 200 fps or at least over 144 for my 144hz monitor. But im so confused what is causing this problem. Every game is affected by this problem so its nothing about a specific game. To give you a quick example: When i play csgo i usually have 400+ fps nevertheless my game feels unsmooth and i cant play normally.
Specs:
Z170-A
32 GB RAM 2666mhz Hyperx Fury
R9 280x Sapphire Vapor Tri-X OC
i7-6700K
SSD 850 Evo 250GB
Noctua Cooler 1
700W power supply by MAXPRO
Toshiba HDD
Monitor: BENQ XL 2411Z (144hz)
Roccat Kone XTD optical
Razer Blackwidow X Chroma
I really belive that u guys can help .
Oh. I probably should include that when I give people the command lol...So no disk issues. Have you checked your CPU and GPU temps while gaming? Run CPUID HWMonitor and report 'em here. With a Noctua cooler on your CPU I doubt it's overheating, but anything is possible.
I was thinking maybe your drive was slower, like 5400 RPM, but a 7200 RPM drive wouldn't cause stuttering unless something's wrong with it. Pull up a command prompt and run chkdisk /f /r then restart your computer; let it do its thing and see if it finds any issues. If that comes up clean, we'll look elsewhere for the culprit.
