[SOLVED] Stutters and low fps garry's mod with a good pc.
Have you anything OC'ed? If so take it off and run again. That includes both CPU/GPU. Mods sometimes aren't stable. Although I shouldn't think your system would have any issue with gmod. But some games just do't respond well to OC's.
Thanks for the answer, and no i havent overclocked all the other people on that server dont seem to have a problem with fps. I'am having this problem on multiple servers. Single player fps is fine
Well, it's not your connection anyway :)
I guess its down to the mod itself. Sometimes they don't work as they should. Your CPU/system is fine. It's not that your hardware can't handle it. It can for sure. Just mods sometimes don't work on all systems. It's not as if they are tested with systems to ensure compatibility.
Try a fresh install of the stock game and mod. See if that helps.
I just tried and no, its not on 100 procent usage but i saw that it is using 40 procent of my ram. I'm now trying the game on my ssd.
EDIT: I just tried on my ssd but i still have 30 fps and stutters
