Sub $600 reliable i3 build for parents
metaxas
40
Trying to build a simple but reliable PC, with known brand names in the build, for parents' use. I might use it for programming (definitely) and gaming (sometimes) whenever I am visiting on vacation. Hope to get the parts ordered asap.
Approximate Purchase Date: This week
Budget Range: <$600
System Usage from Most to Least Important: Mostly internet, MS Word / Excel, some java programming, casual gaming (WOW / Crysis /BioShock)
Parts Not Required: Keyboard, mouse
Preferred Website(s) for Parts: Newegg
Country: US
Parts Preferences: by brand or type: Intel CPU, Asus monitor. No other preference
Overclocking: No
SLI or Crossfire: Maybe
Monitor Resolution: No big deal
Additional Comments: Price, Reliability since parents cannot fix it if broken, works well for surfing and word processing, some programming.
$16.99 SAMSUNG CD/DVD Burner Black SATA Model SH-222AB - OEM
$54.99 Rosewill R101-P-BK-450W MicroATX Mid Tower Computer Case, come with 1x 120mm Fan, 450W Power Supply
$89.99 ASUS VH197D Black 18.5" LED Backlight Widescreen LCD Monitor, VESA Compatible
$39.99 GIGABYTE GV-R645D3-512I Radeon HD 6450 512MB 64-bit DDR3 PCI Express 2.1 x16 HDCP Ready Low Profile Ready Video Card
$5.99 Arctic Silver AA-1.75G Thermal Compound
$34.99 G.SKILL Value Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9D-8GBNT
$49.99 GIGABYTE GA-H61M-DS2 LGA 1155 Intel H61 Micro ATX Intel Motherboard
$99.99 Intel Core i3-540 Clarkdale 3.06GHz LGA 1156 73W Dual-Core Desktop Processor Intel HD Graphics BX80616I3540
$99.99 Microsoft Windows 7 Home Premium SP1 64-bit - OEM
$84.99 Seagate Barracuda ST500DM002 500GB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Total price (all post-rebate): $577.89
Questions:
Any obvious incompatibilities?
Can the price be reduced further?
Do I need a separate fan for the CPU? Is the power supply enough for the build?
Does this system meet the requirements?
Would really appreciate any advice, responses to any of the questions, comments, suggestions.
Thanks!!
Excellent.. Good catch Am2a.. I have updated the build with the correct Mobo. Thanks!!
If you aren't overclocking you'd get better performance out of the original mobo and an i3 2100. Also, I'd try to get a slightly better graphics card in there, maybe an HD 5570/6570 (I know, budgets suck).
Done and done on the CPU and Mobo. Makes perfect sense to change these two. I may stick to the card though, I havent made a decision on it yet. May go with onboard graphics until I decide. I have upgraded the monitor a little.
Thanks!
$89.99 ASUS VW193DR Black 19" Widescreen LCD Monitor, VESA Compatible
$99.99 Intel Core i3-2100 Sandy Bridge 3.1GHz LGA 1155 65W Dual-Core Desktop Processor Intel HD Graphics 2000 BX80623I32100
Total price (all post-rebate): $601.91
Any other suggestions are welcomed ....
