Question Subwoofer Cooling
kennethrjones.cs
Commendable
BANNED
Feb 26, 2023
155
26
1,610
I'm getting this sound system:
https://www.amazon.com/gp/product/B004M18O60
Several of the reviews say this has issues with overheating. I don't intend to play mine loud, it's just for video games on my PC. But I found this picture of the back, and it looks like there is a metal plate on it:
https://m.media-amazon.com/images/I/612Vml777vL._AC_SL1500_.jpg
I was thinking about getting this heatsink that looks like it can stick on. I was wondering if putting this on the back would be helpful, or would it cause any damage, etc.
https://www.amazon.com/gp/product/B08VDX7NNG
Audio does not need to be loud to overheat.
It could simply be poor design with regards to materials, assembly, case layout, etc..
As for the metal plate, the heat sink will only be effective (maybe) if the metal plate is actually intended as a means to radiate heat from the interior.
As another thought, if the back plate is intended for cooling is some manner I would expect there to be some physical vents....
My suggestion is to hold off on doing anything pending more information.
There may be other ideas and suggestions.
Just my thoughts on the matter.
Reactions: kennethrjones.cs
I don't know. There are lots of reviews online of this overheating. I don't know what people are doing to cause it though. Playing at max volume for long periods maybe. I just want this for gaming and YouTube because my current Amazon Basic speakers suck. I never play my stuff loud. I don't listen to music often and when I do, I don't have is blaring. It's just for gaming.
But it does seem like there's an issue with this product because I have seen so many reviews about the same overheating issue.
I guess I can just wait until I get it to see if I have any of the same issues other people are having.
There is one review on Amazon by DerekZ10. It's one of the first pictures with a temperature gauge on it. I don't know how to put a link to a review. In any case, this guy sounds a little unhinged, with his comments about kicking the subwoofer and then complaining that it doesn't work.
Not sure why he would spend $400 on something and throw it on the floor either.
my guess would be that the people who had issues most likely stuck this thing inside a tight space where it could get no airflow. hence it overheated.
you have to take any user review with a large grain of salt. most "errors" are on the user side but THEY TYPE IN ALL CAPS SO IT MUST BE TRUE!!!!!!!
look at professional reviews such as the ones found here
https://duckduckgo.com/?q=Logitech+Z906+review&t=ffab&ia=web
and see what they have to say. if there is truly a problem with design it'll show up on more than a couple random amazon user comments
Thanks everyone.
I'm just going to get it and try without the heatsink and see if I have any issues. If there is a problem, I can try to resolve it when it happens.
It has a 2-year warranty on it, and according to what I found, this speaker system has been available for 14 years on Amazon, so if there were any major issues with overheating, I would think Logitech would have been aware of it and fixed it by now since they are a fairly decent company (unless you're driving a sub 😏).
