Hi all
I just got myself a surround sound system from LG, specifically this one:
http://www.lg.com/uk/home-cinema-systems/lg-HT32S-home-cinema-system
Also here's a picture of how it looks like on the back so people can better understand what I mean:
http://ksassets.timeincuk.net/wp/uploads/sites/54/2009/05/10818-ports-1.jpg
Before I start I just want to point out that I have the system connected to a computer.
Now as you can see on the 2nd link the subwoofer is connected on the left and the speakers in the middle and right, I have done that but the subwoofer doesn't work, it makes no sound at all, but if I connect it into one of the speaker ports it works fine, also if I connect a speaker to the subwoofer ports it works fine but for some reason the subwoofer does not work when connected to the subwoofer ports.
It does work somewhat but when I play music or put on a movie the subwoofer doesn't seem to be giving off that much base, I have a smaller set of speakers with a little subwoofer about 1/3 of the size of the new one but it gives more base then the big one.
I've tried doing sound tests and for some reason only the devices connected to the speaker ports make a sound, the device connected in the subwoofer port makes no sound but if I play music or a movie then all 3 audio devices work fine.
I have tired looking around on google for some help but I haven't found much, I found one article on this site saying I should check my sound settings and make sure it's set to 5.1 which it is so I can't really find anything else that could explain why this is happening or how to fix it.
Hoping somebody out there can.
