Question Such thing as too much cooling?
Nov 4, 2019
Is there such thing as too much air cooling? I was just wondering if you could “freeze” a CPU because of it being cold. Thanks!
No.
Air and liquid cooling are only ever capable of every cooling a CPU close to the temperature of the air around it under perfect conditions.
So If your house is 70 degrees farenheit, your CPU will always be well above 70f with standard cooling.
Unless you are using a chiller unit or liquid nitrogen and trying to get the CPU to run sub zero, your CPU will never be very cold.
Encryption+
Upstanding
Sep 26, 2019
276
56
290
24
As long as they don’t use batteries
Yes but since the question is about PC cooling, batteries aren't really an issue, especially at the relatively warm temperatures possible with air and water cooling systems. But yes batteries are the opposite, they work better the warmer they get within their specified operating temperature range.
Latest posts
