overall I would update the amd chipset driver and
the raid driver from here:
MPG X570S CARBON MAX WIFI (msi.com)
best to do it with a bios update. most likely the root problem that caused the bugcheck.
here are other notes/issues from your memory dump
since you provided a memory.dmp file I can see more details and I am looking at why your video upscale tool did not complete. I am looking at a disk log and it has 2.8 million entries basically calling
PauseAdapter
then ResumeAdapter
all on port 2.
I guess I would ask if this is a raid disk, and if port 2 is a special port for your motherboard. It seems strange to making these calls over and over.
timer shows 11:09:28.338
11:09:28.346
.008 seconds for each cycle.
something is wrong with the drive/controller.
maybe update the BIOS, the CPU chipset, any raid driver and check for drive firmware updates using crystaldiskinfo.exe
it could explain why the upscale .exe is not getting done fast enough. debugger indicates it is a raid driver running.
there are repeated calls to storport!RaidAdapterPowerDownDevice
in the stream of log entries.
Device overheated? problems in sleep functions?
(something is wrong, maybe a raid adapter going to sleep and not waking correctly? might tell the system not to let your drive sleep. ie windows control panel, device manager, right mouse click on the adapter, see if there is a power management tab and uncheck the option to let the device sleep (just for testing))
I would looking at ffmpeg_waifu2xEX.exe and find out if I wanted it running (ie actually using it) and why it ended up using so much physical ram and pagefile.sys space. If you expect it to use a lot, I would make the pagefile bigger.
ffmpeg_waifu2xEX.exe looks like it was running and using a very large amount of memory. window memory compression tried to do some compressing on some of the 3 of the 80 threads and a fault was called.
debugger indicates that the .exe was using
10575600KB of memory space.
VirtualSize 26750 Mb
looks like the tool is some sort of video upscaler/editor
you could reduce the number of threads. I do not know why microsoft was trying to run memory compression on these threads. (other than the system was low on memory) could just be an app bug where one thread does not finish and eats up the ram and virtual memory.
later windows detects the limited free memory attaches to the process and tries run the memcompress on it. it still should not bugcheck, maybe the process did not complete due to some error and was hung?
process used a lot of kernel time and was switched in over 150k times. you have other suspect issues with the machine but this .exe was what lead to the bugcheck.
note 3: owning process was ffmpeg_waifu2xEX.exe
Image: MemCompression attached to it and it led to the bugcheck.
ffmpeg_waifu2xEX.exe has a very large number of threads. three of the threads were in the process of getting a memory compression error. cpu core 13,17 and 20
cpu core was trying to trim the working set for ffmpeg_waifu2xEX.exe looks like it also was in the process of a fault.
note 2: you could also update the BIOS to a more current version (beta or last stable version) then do a clean windows install and not install the ryzenmaster driver and dump any malware at the same time.
note: you have a old version of the bios running that does not have the various security fixes and you have a old version of the ryzenmaster driver running.
(you should update both the driver and bios together)
current beta bios released on 2023-03-03
windows was trying to remove some data from compressed memory, the data had been modified and it ended up using a bogus
memory address ( 000000000000aa00 )
A address like this could be an indication of malware trying to infect your system. I would guess it is coming from your internet download manager but it does look like you have several replaced drivers.
I would, use autoruns to remove the download manager.
turn off the system virtual memory to delete the pagefile.sys.
run cmd.exe as an admin then run
dism.exe /online /cleanup-image /restorehealth
then reboot and turn on virtual memory again to create a new pagefile.sys.
at this point I would run a malware scan to see if i could find any malware on your system.
download and run microsoft autoruns64 from here:
Autoruns for Windows - Sysinternals | Microsoft Learn
find the driver:
\SystemRoot\system32\DRIVERS\idmwfp.sys Wed Dec 19 06:52:11 2018
and delete it. (internet download manager by by Tonec )
other suspect drivers:
\SystemRoot\System32\Drivers\Fs_Rec.sys unavailable (FFFFFFFE)
\SystemRoot\System32\drivers\volmgrx.sys unavailable (FFFFFFFE)
Msfs.SYS unavailable (FFFFFFFE)
some windows files have been modified:
\SystemRoot\System32\win32kfull.sys
note:
seems weird to have
Intel Telemetry Driver and Intel Power Engine Plugin installed on a amd based motherbooard
AMDRyzenMasterDriver.sys Thu Jun 24 22:21:58 2021 running.
machine info:
BIOS Version 1.40
BIOS Starting Address Segment f000
BIOS Release Date 08/11/2022
Manufacturer Micro-Star International Co., Ltd.
Product MPG X570S CARBON MAX WIFI (MS-7D52)
Processor Version AMD Ryzen 9 5900X 12-Core Processor
Processor Voltage 8bh - 1.1V
External Clock 100MHz
Max Speed 4950MHz
Current Speed 3700MHz
Hi! I'm sorry for late reply. While creating the account I probably turned on notification for everything and it got flooded so didn't notice your response.
As Colif mentioned, I got in touch with him since I couldn't post my reply here. I used the upscaler many times before but never for a 8K video. It ran fine in past within 4K limits.
My RAM:
https://www.corsair.com/us/en/Categ...geance-RGB-PRO-SL-White/p/CMH16GX4M2D3600C18W
My SSD:
https://www.samsung.com/us/computin.../980-pro-pcie-4-0-nvme-ssd-1tb-mz-v8p1t0b-am/
Now here is the issue I found with my RAM operating at 3200mHz without XMP:
Log Name: System
Source: Microsoft-Windows-MemoryDiagnostics-Results
Date: 08/03/2023 05:52:16 PM
Event ID: 1102
Task Category: None
Level: Error
Keywords:
User: SYSTEM
Computer: Ash
Description:
The Windows Memory Diagnostic tested the computer's memory and detected hardware errors. To identify and repair these problems, contact the computer manufacturer
Event Xml:
<Event xmlns="
http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-MemoryDiagnostics-Results" Guid="{5f92bc59-248f-4111-86a9-e393e12c6139}" />
<EventID>1102</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000000</Keywords>
<TimeCreated SystemTime="2023-03-08T11:52:16.6268364Z" />
<EventRecordID>25264</EventRecordID>
<Correlation />
<Execution ProcessID="8668" ThreadID="8664" />
<Channel>System</Channel>
<Computer>Ash</Computer>
<Security UserID="S-1-5-18" />
</System>
<UserData>
<Results xmlns="
http://manifests.microsoft.com/win/2005/08/windows/Reliability/Postboot/Events">
<LaunchType>Manual</LaunchType>
<CompletionType>Fail</CompletionType>
<MemorySize>16308</MemorySize>
<TestType>10</TestType>
<TestDuration>1192</TestDuration>
<TestCount>12</TestCount>
<NumPagesTested>4152916</NumPagesTested>
<NumPagesUnTested>1749</NumPagesUnTested>
<NumBadPages>7</NumBadPages>
<T1NumBadPages>0</T1NumBadPages>
<T2NumBadPages>0</T2NumBadPages>
<T3NumBadPages>0</T3NumBadPages>
<T4NumBadPages>0</T4NumBadPages>
<T5NumBadPages>1</T5NumBadPages>
<T6NumBadPages>1</T6NumBadPages>
<T7NumBadPages>0</T7NumBadPages>
<T8NumBadPages>1</T8NumBadPages>
<T9NumBadPages>0</T9NumBadPages>
<T10NumBadPages>0</T10NumBadPages>
<T11NumBadPages>3</T11NumBadPages>
<T12NumBadPages>1</T12NumBadPages>
<T13NumBadPages>0</T13NumBadPages>
<T14NumBadPages>0</T14NumBadPages>
<T15NumBadPages>0</T15NumBadPages>
<T16NumBadPages>0</T16NumBadPages>
</Results>
</UserData>
</Event>
My PC failed to turn on with XMP on at max RAM advertised speed which is 3600mHz. So I turned XMP on but set frequency to 3200mHz. It turned on just fine, and I ran another Memory Diagnostics test.
Here is the result:
Log Name: System
Date: 09/03/2023 11:21:29 PM
Event ID: 1102
Task Category: None
Level: Error
Keywords:
User: SYSTEM
Computer: Ash
Description:
Event Xml:
<Event xmlns="
<System>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<TimeCreated SystemTime="2023-03-09T17:21:29.6954271Z" />
<EventRecordID>26095</EventRecordID>
<Correlation />
<Execution ProcessID="9040" ThreadID="9036" />
</System>
<UserData>
<Results xmlns="
<NumBadPages>3</NumBadPages>
<T6NumBadPages>0</T6NumBadPages>
<T8NumBadPages>0</T8NumBadPages>
<T11NumBadPages>2</T11NumBadPages>
<T12NumBadPages>0</T12NumBadPages>
</Results>
</UserData>
</Event>
Number of bad pages vary in both cases, not sure whether it means anything or not. Memtest also found error in both cases.
Set the RAM to auto, aka 2133mHz and both Diagnostics tools and memtest showed 0 error.
I'm utterly confused now. Did the BSOD happened because running Waifu2x at 8K made it utilize the ram to 100% which means it accessed the bad pages of the ram and crashed? Is my RAM faulty? Or is the issue something else entirely?
I don't think device overheated but can't be sure as I wasn't paying attention to the metrics. Waifu2x usually makes my GPU temperature less than 70
°C but CPU temp 65-69
° C. Sleep function...if you meant Sleep Mode, it's off. High Performance is selected with disk never going to sleep.
I don't use Ryzen Master itself. Some drivers must've came with Adrenalin but that's it, which itself is outdated. Considering how unpredictable AMD drivers are I'm a bit concerned about updating and farther breaking my system tbh. Virtualization is off iirc. As for other stuffs that came with it, the OS was setup by the company from where I purchase the PC components. When I claimed warranty on PSU back in November they set it up again from scratch since Adrenalin 22.10.2 almost broke it completely, making it unstable. They also partitioned my SSD and made it a clean installation from scratch. Afaik they checked all components then and only found a faulty PSU, not sure how true that is.
Since I didn't do the memtest when I created this thread, it lacked information. Which I hope I provided now. Let me know what you think.
Edit 1: Did a full scan of the system last month using Windows Defender, which is always up-to-date. It found nothing.
