Sudden Drop To 30 FPS When My System Usually Does 100+
Genrk19
Commendable
Oct 9, 2016
14
After moving PC to my dads for the holidays, I have got a solid 30 fps constant in Overwatch (my most played recent game). I am using a relatively old tv screen but I didn't think that would result in the massive frame drop. The cpu temp is constantly 28 degrees Celsius. Also it is relatively clean as I got a new case a couple of months ago, although the gpu, cpu are second hand.
Specs:
GA-H81M-S2H
i7 4790
Asus 750 Ti
8GB ddr3
EVGA 600W
DEEPCOOL GAMMAXX 300 CPU Cooler
please help soon....
I will attempt that now but no the fps goes from 24 to 36 and never goes out of that range.
Update:
I have turned vsync on and it has made no difference, the overwatch home screen is very pixelated and so I think it may be a resolution problem. The lowest resolution was only something like 1080x800 (idk) but it made no difference.
