Sudden fps drop all games less than 20 fps
Ndneos
7
So it all happen within a spend of one night. The night before I was able to run overwatch with at around 190 fps. Shut computer off and turn it back on the next morning. Overwatch ran at 5 fps. I tested it on all games from cs go, and nier automata and same result for all of them less than 10fps.
At first I thought it was a malware or a bitcoin miner that was causing the problem as i download a few mp3 files, but after multiple attempt nothing. My computer was clean.
I then checked the temperature of cpu and gpu. 36c gpu at idle and 40c cpu at idle.
So as a last resort I reset my computer and still didn't solve the problem. Overwatch was still running at 5fps.
my rig:
i5 4690k
Gigabtye gtx 970 mini GV-N970IXOC-4GD
8gb ram
High Power 600 watt power supply
Gigabyte GA-Z97X-SLI motherboard
Okay when I connect to my igp, the fps drops even lower and CPU usage is basically at 100%. The blizzard launch app wont load completely but still usable. So is it possible that my CPU is bad?
There are some screenshots of my CPU performances while it is using the igp
http://imgur.com/o0SZ0SZ(Performance while Overwatch is running)
http://imgur.com/r49zN1T (Performance after I close the game and the Launcher)
http://imgur.com/5prCKs1 (How it looks in-game) The graphics setting was set to low
Temps in-game are around 40-50C
No, not restart, reset like you know how you can completely reset your setting to factory setting and remove all files and apps.
When you go to windows 10 setting, to update and security, recovery, and the option "reset this pc" lol
Ok that makes sense now.
What are temps while on load?
See since the fps was already like at 1-3 fps in the menu, I never actually started a match, while in the menu the temp was between 40-50C. (Still talking about when using the igp)
