Question Sudden Low FPS in Fortnite when it was previously running smoothly ?
Jan 29, 2024
Fortnite was running properly until recently. Most recent change was a Windows update but that is about it. GPU driver is updated and I've lowered all graphics settings, but still only getting 30 FPS at most.
All my other games such as Overwatch run smoothly at high settings.
Here are the user benchmark settings i took!
https://www.userbenchmark.com/UserRun/67141589
Game 58%, Desk 87%, Work 56%
Specs:
Mbd: Asrock B550M Pro4
CPU: AMD Ryzen 5 3600 - 79.8%
GPU: AMD RX 5700-XT - 67%
SSD: Crucial P1 3D M.2 NVMe 500GB - 149.7%
RAM: Unknown TEAMGROUP-UD4-3600 2x16GB - 71.2%
Hey there,
Your GPU is registering as zero (0). If you have an overlay like MSI Afterburner OSD etc (any overlay at all), then disable them and run the test again. It's zero because of the overlay
As for the test itself. It's a junk, that is hardly useful. It does however show us that your ram is running at Jedec default. You need to turn on XMP for your ram, this will give you a huge boost. You should get much better scores.
Let us know how that goes.
Reactions: Order 66
