So for the past couple of days some of the games which used to run at 60+ fps all of a sudden are running extremely slow now.
These titles don't seem to utilize the CPU and GPU at all for some reason.
For example Witcher 3/Grand Theft Auto 5 used to run almost maxed out at a stable playable FPS just a couple of days back. I never bothered to check the CPU/GPU usage then. The temps used to go up (don't remember how much, so pls don't ask) and I could notice the increase in rpm of the fans. But now both games manage only around 10fps.
I first noticed this problem when I recently purchased Skyrim SE from steam. The game launcher detects the hardware and presets the settings to ULTRA but the game barely manages 10 fps and CPU and GPU usage are around 20% and 10%. Temps stay between 40-55 deg. C so the fans don't spin up at all or stay around 700 rpm. Power draw is close to idle (25-30 watts). I tried lowering the settings but no use.
For some reason Bioshock infinite, Far Cry 3 (dx10), Crysis 1 (non remasted), Arkham Origins, Factorio dont seem to be affected at all and I can get a stable fps settings maxed out. GPU/CPU usage is up and power draw is up and around 80 watts.
Far Cry 3 (dx11) is a different story tho same as Skyrim (10 fps).
PCSX2 (playstation 2 emulator) runs perfectly with OpenGL renderer (100+ fps). CPU/GPU usage is up from idle and power draw is also high but performance with Dx11 renderer gets really choppy (30fps) for the same game as CPU/GPU usage go down.
Please keep in mind that I have played all the above mentioned games on the same system over the years with no problem at all. So this is not a problem of the hardware not meeting the requirements of the games.
My Config
Intel Core i5 4670k
Intel B85 mobo
GTX 960 4gb
16gb ddr3
750 watts power supply
Things I have tried so far
I know this is a long post but I have tried to put all the details I can recall so you guys understand the situation better.
I finally managed to get a few days off from work and really wanted to play Skyrim and Arkham knight and then this happens 🙁
My Config
Intel Core i5 4670k
Intel B85 mobo
GTX 960 4gb
16gb ddr3
- I have checked all the cables and connectors for any defects and couldn't find any.
- Installed my friends rtx 3070 FE and the behavior is similar to my 960 as above.
- Uninstalled GPU drivers using DDU in Safe mode and reinstalled older drivers.
- Uninstalled GPU drivers using DDU in Safe mode and reinstalled latest drivers.
- Complete format and a fresh windows installation. No luck still 🙁
- Updated direct x
- Cursing at it.
