Question Sudden no signal and fans loud
I'd still run a full virus scan and a Malwarebytes scan just to eliminate that possibility. Maybe a CCleaner run too in case it was a software conflict or registry error. After that maybe check for pgms running in the background when you game that can be disabled. If the issue still occurs, then you can probably assume it is hardware.
Running a memtest scan (one stick at a time for one full pass) is one I forgot to recommend you do. Might be a bad stick of RAM too.
