Sufficient cooling need ideas
RiverDude1
Basically i built this computer in mid 2012 and am thinking i need a new cooling configuration, in addition to a 3D compatible video card and a new cpu cooler and or new cpu.
Current video card just isn't sufficient any more after i got my new monitor.
Got any ideas let me know.
ASUS VG248QE Black 24" 144Hz 1ms
ASUS HD7850-DC2-2GD5-V2 Radeon HD 7850 2GB 256-Bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
1 x ASUS HD7850-DC2-2GD5-V2 Radeon HD 7850 2GB 256-Bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video ...
AMD FX-8150 Zambezi 8-Core 3.6GHz Socket AM3+ 125W FD8150FRGUBOX Desktop Processor
1 x AMD FX-8150 Zambezi 8-Core 3.6GHz Socket AM3+ 125W FD8150FRGUBOX Desktop Processor
1 x 1 Yr Service Net Replacement Plan For Item#N82E16819103960
LITE-ON 24X DVD Writer Internal Model ihas324
1 x LITE-ON 24X DVD Writer Internal Model ihas324
Western Digital Black WD1002FAEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive Bare Drive
2 x Western Digital Black WD1002FAEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive Bare Drive
1x ASUS Crosshair V Formula-Z AM3+ AMD 990FX + SB950 8 x SATA 6Gb/s USB 3.0 ATX AMD Gaming Motherboard with 3-Way SLI/CrossFireX Support and UEFI BIOS
1x
Patriot Viper 3 32GB (4 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model PV332G160C0QK
1 x RAIDMAX RX-1000AE 1000W ATX12V v2.3 / EPS12V SLI Certified CrossFire Ready 80 PLUS GOLD Certified Modular Active PFC Power Supply
1 x Corsair Force Series GT CSSD-F120GBGT-BK 2.5" 120GB SATA III Internal Solid State Drive (SSD)
10/20/2012
1 x Thermaltake Chaser Series Chaser MK-I (VN300M1W2N) Black SECC ATX Full Tower Computer Case
If you are looking for a new GPU, I use an XFX R9 290 Black OC edition GPU because they are only $250 on Amazon. If you want to spend the money get something around it or higher, here is a Hierachy here on Tom's: http://www.tomshardware.com/reviews/gaming-graphics-card-review,3107-7.html
What type of cooling are you looking for?
If you are wanting to just cool CPU Grab a Closed loop water cooler like Corsair's H75. 15 minute installation, no refiling or monitoring needed, comes with AMD socket options.
GPU can use the same thing if you buy a water cooling bracket like the NZXT Kraken G10 to mount another radiator loop.
I personally use 2 Corsair AF120 fans for intake on my case, an H55 water loop for my CPU(AMD FX8320). XFX's cooler is sufficient for my GPU thus far on its own.
i really like that cpu cooler thanks for the information im just not shure if i have room on my board for it
A closed water loop takes up less space on the board itself than an Air cooler since the Radiator sits away from the board.
You will unscrew the bracket currently around the CPU socket(the two black plastic clips with 2 screws each) and mount the one for the water cooler in their place. Includes a back plate. You can then mount the Fan and Radiator together at the top of the case pulling air through it. The Pump and Fan will both use 1 3-pin fan connector, you can use 2 of the 3 at the top of your board as pictured, I assume one or two of those is labeled CPU.
Here is an example of how it will sit on the board(in this photo they have the radiator mounted on the back instead of the front but the pump is the same)
