Will a rose will 550w bronze certified PSU provide sufficient/enough energy for a system with the rtx 2070?
Thx
Thx
You want a higher wattage and a better brand like corsair or thermaltake. Recommended is a 650 Watt
Recommended System Power (W)3 550W
3 - Recommendation is made based on PC configured with an Intel Core i7 3.2 GHz processor. Pre-built system may require less power depending on system configuration
