H hafijurrahaman884 Oct 28, 2018 2 0 10 Oct 28, 2018 #1 You can suggest ryzen ......but I need alws a good motherboard
Solution C C Calvin7 Oct 28, 2018 AMD RYZEN 3 2200G $100 https://www.newegg.com/Product/Product.aspx?Item=N82E16819113481&Tpk=N82E16819113481 ASRock A320M-DGS $50 https://www.newegg.com/Product/Product.aspx?Item=N82E16813157767&cm_re=AMD_A320_mobo-_-13-157-767-_-Product HyperX FURY 8GB (2 x 4GB) 288-Pin DDR4 SDRAM DDR4 2666 (PC4 21300) Intel X99 Desktop Memory Model HX426C15FBK2/8 $84 https://www.newegg.com/Product/Product.aspx?Item=N82E16820104571 CORSAIR CX-M Series CX450 $26.99 after $20.00 rebate card https://www.newegg.com/Product/Product.aspx?Item=N82E16817139146 WD Blue 1TB Desktop Hard Disk Drive - 7200 RPM SATA 6Gb/s 64MB Cache 3.5 Inch - WD10EZEX - OEM $46...
N norcalsc Dignified Feb 9, 2018 3,282 144 15,090 Oct 28, 2018 #2 You are requesting a system without gpu but it has to be a good motherboard? What are you trying to accomplish? Upvote 0 Downvote
N norcalsc Dignified Feb 9, 2018 3,282 144 15,090 Oct 28, 2018 #3 I mean is this going to be a gaming pc or just for Web browsin Upvote 0 Downvote
C Calvin7 Titan Feb 19, 2013 11,722 336 76,490 Oct 28, 2018 Solution #4 AMD RYZEN 3 2200G $100 https://www.newegg.com/Product/Product.aspx?Item=N82E16819113481&Tpk=N82E16819113481 ASRock A320M-DGS $50 https://www.newegg.com/Product/Product.aspx?Item=N82E16813157767&cm_re=AMD_A320_mobo-_-13-157-767-_-Product HyperX FURY 8GB (2 x 4GB) 288-Pin DDR4 SDRAM DDR4 2666 (PC4 21300) Intel X99 Desktop Memory Model HX426C15FBK2/8 $84 https://www.newegg.com/Product/Product.aspx?Item=N82E16820104571 CORSAIR CX-M Series CX450 $26.99 after $20.00 rebate card https://www.newegg.com/Product/Product.aspx?Item=N82E16817139146 WD Blue 1TB Desktop Hard Disk Drive - 7200 RPM SATA 6Gb/s 64MB Cache 3.5 Inch - WD10EZEX - OEM $46 https://www.newegg.com/Product/Product.aspx?Item=N82E16822236339&cm_re=wd_blue-_-22-236-339-_-Product Windows 10 Home - Full Version 32 & 64-bit (USB Flash Drive) $120 https://www.newegg.com/Product/Product.aspx?Item=N82E16832397825&ignorebbr=1 Upvote 0 Downvote Solution
