Suggest PSU for my build!!
JaSoN_cRuZe
457
40
10,890
My config is
i5 3570k
Z77 Mobo
Hyper 212X
2xCorsair Vengeance DDR3 4GB 1600 Mhz(DIMM)
RX 580
1x7.2k HDD
1xDVD-ROM
2x120mm FAN
3x80mm FAN
Suggest me a PSU for my spec and also gonna overclock both GPU(to max) and CPU (to 4.5GHZ).
What is your budget and country? The markets and availability depends on this the most. In general this is what i would recommend:
Limited/tight Budget:
https://pcpartpicker.com/product/fZyFf7/seasonic-power-supply-s12ii520bronze
OR
https://pcpartpicker.com/product/FQ648d/corsair-power-supply-cp9020101na
But for your build (especially since Overclocking) i would look into either of these:
https://pcpartpicker.com/product/Rp8H99/corsair-power-supply-cp9020091na
OR
https://pcpartpicker.com/product/9q4NnQ/evga-power-supply-220g20650y1
Please note this is in U.S prices/shops. Hope this helps :)
OR
OR
I'm in India, Please neglect evga psu's not available and overpriced extremely. Btw is Corsair cx450m enough for my build if i OC, i have Antec VP450P currently
I think I might use my vp450p meanwhile it restocks using 6pin to 8pin adapter for rx 580, the 620 seasonic is 6.2k, 520 is 5.6k and 500 is 4.7k I think the vp450p can handle it from this review
http://translate.google.com/translate?sl=auto&tl=en&js=n&prev=_t&hl=en&ie=UTF-8&layout=2&eotf=1&u=http%3A%2F%2Fwww.easycom.com.ua%2Fpower%2Fantec_basiq_vp450p%2F%3Flang%3Dru
