jitkr Honorable Jan 13, 2014 37 0 10,540 Mar 28, 2015 #1 Hey guys, Suggest me some decent entry level mouse for little gaming and daily usage. Should be compatible with Windows 8.1. Budget 1800INR [Flipkart] can also go for 3000 INR but i think entry level mouse can be purchased under 2k.
Solution FreshPineApples Mar 28, 2015 This is a good mouse for the price: http://www.flipkart.com/logitech-g402-wired-optical-mouse/p/itmefcp7qgm3fhqy?pid=ACCEFCP65ZZBFQSE&otracker=from-search&srno=t_3&query=mouse&ref=fb42c7b9-4d7d-408c-a3f8-8d045552a5af
FreshPineApples Reputable Jun 20, 2014 493 0 4,960 Mar 28, 2015 Solution #2 This is a good mouse for the price: http://www.flipkart.com/logitech-g402-wired-optical-mouse/p/itmefcp7qgm3fhqy?pid=ACCEFCP65ZZBFQSE&otracker=from-search&srno=t_3&query=mouse&ref=fb42c7b9-4d7d-408c-a3f8-8d045552a5af Upvote 0 Downvote Solution
jitkr Honorable Jan 13, 2014 37 0 10,540 Mar 28, 2015 #3 FreshPineApples : This is a good mouse for the price: http://www.flipkart.com/logitech-g402-wired-optical-mouse/p/itmefcp7qgm3fhqy?pid=ACCEFCP65ZZBFQSE&otracker=from-search&srno=t_3&query=mouse&ref=fb42c7b9-4d7d-408c-a3f8-8d045552a5af Is this mouse dedicated to gaming or can it be used for general purpose also. Is it compatible with Windows 8.1 Upvote 0 Downvote
FreshPineApples Reputable Jun 20, 2014 493 0 4,960 Mar 28, 2015 #4 The mouse can be used for general purposes too and yes it is windows 8.1 compatible. Upvote 0 Downvote
jitkr Honorable Jan 13, 2014 37 0 10,540 Mar 28, 2015 #5 FreshPineApples : The mouse can be used for general purposes too and yes it is windows 8.1 compatible. A special kind of mouse pad is needed or it can be used on any mouse pad(local one) 😀 Upvote 0 Downvote
FreshPineApples Reputable Jun 20, 2014 493 0 4,960 Mar 28, 2015 #6 Any mouse pad will be fine Upvote 0 Downvote
