Suggest the best power supply in $100, $200 and $300 range
pinky10
11
Hello I have bought these parts so far
ASRock Z97 Extreme6
I7-4790K
2x GTX 760 Ti
4 DDR3 Crucial (16GB, 1600)
and I already have these:
2x 1TB WD Passports
2x 2TB WD Passports
1x DVD Writer (Read/Writes DVDs/CDs)
1x 64GB SSD AData
1x 256GB SSD AData
I would appreciated very much If you could suggest 3 power supply to me
1 in $100 range
1 in $200 range
1 in $300 range
Thanks.
Corsair RM/HX/AX line up seems to be reliable.
(always get full modular)
Depending on your wattages, SeaSonic, silverstone, corsair, and a very limited amount of fractal design PSU's are also great choice.
All made by the best Super Flower.
http://pcpartpicker.com/parts/compare/evga-power-supply-220g20750xr%2Cevga-power-supply-220p21000xr%2Cevga-power-supply-220p21600x1/
Compare here.
Only 2 pieces of data are really relevanta s everything else is too small to worry about.... since it's not a X79/X79 build w/ big OC, only the GFX card is really relevant.
PSU requirements according to nVidia are the same for both the 760 and 760 Ti (500 for system and 1st card and 170 extra for each additional.
http://www.guru3d.com/articles_pages/geforce_gtx_760_sli_review,4.html
Here is Guru3D's power supply recommendation:
GeForce GTX 760 - On your average system the card requires you to have a 550 Watt power supply unit.
GeForce GTX 760 2x SLI - On your average system the cards require you to have a 700~800 Watt power supply unit as minimum.
GeForce GTX 760 3x SLI - On your average system the cards require you to have a 1000~1200 Watt power supply unit as minimum.
Though we do have some reserves calculated into our recommendation remember this; if you are going to overclock the GPUs or processor, then we do advise you purchase something with some more stamina.
I am surprised to see that you bought two 760 Tis as i thought this card was OEM only.
If doing stock or moderate overclocking on CPU / GPUs, I'd opt for the $60 EVGA B2 750 (9.0 Performance / 9.5 Build Quality)
http://pcpartpicker.com/part/evga-power-supply-110b20750vr
If doing moderate to high overclocking on CPU / GPUs, I'd opt for the $105 EVGA G2 750 (10.0 Performance / 9.5 Build Quality)
http://pcpartpicker.com/part/evga-power-supply-220g20750xr
If looking for maximum overclocking on CPU / GPUs, I'd opt for the $135 Seasonic X-850 (10.0 Performance / 10.0 Build Quality)
http://pcpartpicker.com/part/seasonic-power-supply-x850
You can spend more money but it's not going to give you anything ... well maybe .... if i had a white case I'd be tempted get the new Seasonic snow edition .... so far only an 1150 watt model but damn perty and another perfect 10.0 Performance / 10.0 Build Quality rating from jionnyguru .... but that will let ya spend $250
Corsair RM has issue....poor build quality (7.0) in the smaller sizes ... And poor caps in the larger
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story6&reid=363
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story6&reid=369
The HX series are very good ... at least the 650-850 watters, the 1000 and 1050 were dogs.
As for full modular, it's actually of no value unless you are resleeving the cables. Hybrid or semi modular is actually better as it reduces costs and potential failure points, lowers resistance and increases efficiency. The advantage of modularity is being able to leave unused cables in the box.... But there's no advantage to having a modular 24 pin cable as you can't build a OC w/o it. Hybrid / semi modular hard wires all absolutely necessary cables and leaves all the rest modular so no downside.
