Question Suggested power supply, cable for NVIDIA 3070 Ti
Omprakash_2
4
Hi, I have a Asus Z790-A motherboard and a Core i5 13600K CPU. I also have an NVIDIA RTX 3070 Ti GPU. My interest is mostly machine learning. Need advice on reliable PSU - I am assuming 850 watts will be OK. Also where the heck do I get a cable to connect my GPU to the power supply. Any advice - suggestions would be gratefully appreciated.
DSzymborski
Anything on Tier A and only Tier A is appropriate for a high-end GPU.
Cables come with PSUs. This is extra important because PSU cables are not standardized on the side that connects to the PSU, and cables for the wrong PSU can fry the PSU, the GPU, and more.
Vic 40
Ambassador
I also have an NVIDIA RTX 3070 Ti GPU. Also where the heck do I get a cable to connect my GPU to the power supply.
If you have a founders edition and it's new or even used should it have an adapter to connect it to the pcie cables of the psu you'll buy.
If you want a more clear answer to what psu, give people a max budget and the shop you will buy from.
