Suggestion about my water cooling components?
dota2er
147
I have already chosen some water cooling components. But I dont know whether it is compatibility with each others. So please tell me if any of each is wrong or missed. Here is the water cooling parts:
EK FC Bridge Blank:
http://www.frozencpu.com/products/17486/ex-blc-1352/EK_FC_Bridge_Dual_Parallel_3-Slot_CSQ_-_SLI_Connection_-_Acrylic_EK-FC_Bridge_DUAL_Parallel_3-Slot_CSQ_Plexi.html?id=k8oiMQDn&mv_pc=2026
EK FC Bridge Dual Parallel:
http://www.frozencpu.com/products/17486/ex-blc-1352/EK_FC_Bridge_Dual_Parallel_3-Slot_CSQ_-_SLI_Connection_-_Acrylic_EK-FC_Bridge_DUAL_Parallel_3-Slot_CSQ_Plexi.html?id=k8oiMQDn&mv_pc=2026#blank
CPU Block: http://www.frozencpu.com/products/16252/ex-blc-1132/EK_Supremacy_Universal_CPU_Liquid_Cooling_Block_-_Nickel_EK-Supremacy_-_Nickel.html?id=k8oiMQDn&mv_pc=2031
GPU Block: http://www.frozencpu.com/products/22130/ex-blc-1581/EK_GeForce_780_GTX_Ti_VGA_Liquid_Cooling_Block_-_Nickel_Acetal_EK-FC780_GTX_Ti_-_AcetalNickel.html?id=k8oiMQDn&mv_pc=2032
Radiator: http://www.frozencpu.com/products/14315/ex-rad-311/EK_Ultimate_Performance_CoolStream_240_XTX_Series_Liquid_Cooling_Radiator_EK-CoolStream_RAD_XTX_240.html?id=k8oiMQDn&mv_pc=2033
Tubing: http://www.frozencpu.com/products/17585/ex-tub-1577/PrimoChill_PrimoFlex_Advanced_LRT_Tubing_12ID_x_34_OD_-_10ft_Retail_Pack_-_Clear_PFLEXA10-34.html?id=k8oiMQDn&mv_pc=2034
Fitting #1: http://www.frozencpu.com/products/10037/ex-tub-606/Bitspower_G14_Thread_12_ID_x_34_OD_Compression_Fitting_-_Matte_Black_BP-MBCPF-CC5.html?id=k8oiMQDn&mv_pc=2025
Fitting #2: http://www.frozencpu.com/products/20260/ex-tub-1833/XSPC_G14_45_Degree_Rotary_Adapter_-_Chrome.html?id=k8oiMQDn&mv_pc=2035
Fitting #3: http://www.frozencpu.com/products/20262/ex-tub-1835/XSPC_G14_90_Degree_Rotary_Adapter_-_Chrome.html?id=k8oiMQDn&mv_pc=2036
BTW, I prefer a silent build to high effective build. Please tell me if you have any suggestion, Thanks 😀
you need more radiator if you want to run silently. you should get the xtx 360.
you also need a pump.
edit: I cant tell if you are going to be doing SLI or not. If you doing SLI, you will need even more then a 360 rad
Thanks for answering. I should have 2, and my case is Corsair 600t graphite; so I need a 200*200mm radiator in the front of my case. However I only find one radiator which is 200*200(Phobya Xtreme 200) is out of stock. In addition, the xtx 360 isnt fit my case, so I do have to use 240mm radiator on top.
Yes, I knew that. My plan is one 240mm radiator(not space for 360mm) on top and one 200mm(out of stock now🙁) radiator in the front. In addition, can you tell me does all my compatibility with each others?😀
Wow pleases here us the radiators are what cool your system not the water blocks without enough radiator to support the system it will heat up to undesirable temperatures. On a three component system I would use two 360mm radiators to keep them cool.
Do you plan on doing any overclocking?
Well thanks. I am not going to overclock much. But as I said, I use a corsair 600t special edition case, I cant find where I can place a 360mm radiator, what my plan is use a 240mm radiator on top of my case, and one Phobya Xtreme 200mm Radiator in the front of my case when it is in stock. Also, would you could you please tell me whether I chose right tubing and fittings? If you dont mind please recommend some silent pump for me. thanks😀
Well I build systems and custom loops much like you plan to do, I have some picks of the components that I use and the system that I have built, I hope this helps.
well if you have some questions let me know
I use norprene tubing 3/8 ID, 5/8 OD
i use bitspower fittings there is nothing safer or better on the market
i use D5 pumps there quite and last a long time
