Suggestion for replacement other than Digi WR11XT cellular router modem
Sep 19, 2018
Greetings all,
I am using DIGI WR11xt cellular modem with Verizon SIM service in outdoor highway areas as communication medium for Tx/Rx data.
My issues with it are as follow:
1. SIM service is poor
2. Modem if failed, then requires on-site reboot (which takes time, money and person hours as these work sites are isolated after commissioning)
At the end I replace modem with new unit.
So planning to find a substitute which is more robust and good for outdoor use and communication
Any suggestion/comments would be helpful.
Thanks
Sep 19, 2018
Thanks for reply kanewold.
I checked this product. Seems similar. In our application, we apply port forwarding rules and security to Digi wr11xt model using it's web interface. Does this product has something similar? Didn't see on its online PDF
kanewolf
I have no idea. I would contact their technical pre-sales folks. They will have the answer. Also get the user's manual.It may have the answers you need.
