Suggestion on Power Supply
Tony Donev
100
In my opinion current build's psu is to much for OCing i5 ?
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($219.00 @ Amazon)
CPU Cooler: Phanteks PH-TC14PE_BK 78.1 CFM CPU Cooler ($74.99 @ Amazon)
Motherboard: ASRock Z97 EXTREME4 ATX LGA1150 Motherboard ($128.99 @ Newegg)
Memory: G.Skill Sniper Series 8GB (2 x 4GB) DDR3-2133 Memory ($89.98 @ OutletPC)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive ($129.97 @ Amazon)
Video Card: PowerColor Radeon R9 290 4GB PCS+ Video Card ($369.99 @ Newegg)
Case: Cooler Master HAF 912 ATX Mid Tower Case ($49.99 @ Newegg)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply ($69.99 @ Newegg)
Total: $1132.90
Generated by PCPartPicker 2014-08-12 14:58 EDT-0400
XFX TS 550W is,in my opinion,the best solution you have.
Also,the Sapphire R9 290 Vapor-X is also the best solution.Sapphire is the best brand for AMD cards.
You can't really have too much PSU, the one you picked will be fine. You would probably do just as well with a 550 or 600 watt supply too, but there is nothing detrimental to picking a supply that has more capacity other than some minor changes in how efficient it is but even that is only a couple of percent difference which realistically isn't worth considering in the grand scheme of things.
If you wanted to try to shave a few dollars off the top you might consider:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151096 (Only 5 bucks, but a nice supply)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371031 (on sale pretty cheap)
Either that or the one you have, like I said it will do just fine.
Tony Donev
100
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.98 @ OutletPC)
Storage: Crucial MX100 256GB 2.5" Solid State Drive ($109.99 @ TigerDirect)
Video Card: Sapphire Radeon R9 290 4GB Vapor-X Video Card ($447.99 @ SuperBiiz)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply ($70.98 @ Newegg)
Total: $1146.90
Generated by PCPartPicker 2014-08-12 15:37 EDT-0400
How is this for a change
