J Joey2332 Prominent Feb 14, 2017 71 0 630 May 4, 2017 #1 Hello! What would be a good CPU cooler that would fit with an i5-6600? Thanks!
Solution urbancamper May 5, 2017 What case do you have? Do you know how much clearance there is? A Cooler Master Hyper 212 evo would work if you have enough clearance. https://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
Lucky_SLS Glorious Dec 16, 2016 8,396 1,135 45,340 May 5, 2017 #2 a cooler master hyper 212 evo Upvote 0 Downvote
urbancamper Distinguished Apr 10, 2011 1,196 2 19,960 May 5, 2017 Solution #3 What case do you have? Do you know how much clearance there is? A Cooler Master Hyper 212 evo would work if you have enough clearance. https://www.newegg.com/Product/Product.aspx?Item=N82E16835103099 Upvote 0 Downvote Solution
schwatzz Distinguished Jun 23, 2014 788 4 19,365 May 5, 2017 #4 Cryorig H7 is supposed to be pretty good. https://www.newegg.com/Product/Product.aspx?Item=9SIA4UF2DZ6565 Upvote 0 Downvote
urbancamper Distinguished Apr 10, 2011 1,196 2 19,960 May 5, 2017 #5 I like the H7. Because it is offset it will for sure clear the memory if you have 4 sticks. It is a better idea. Upvote 0 Downvote
C Chugalug_ Titan Jan 28, 2016 16,502 4 74,965 May 5, 2017 #6 You don't need a cooler for the 6600. Also why are you buying last gen? Upvote 0 Downvote
