Question Suggestions for a wireless keyboard
iMatty
1,239
144
11,390
Hey,
I was looking for a wireless mechanical keyboard that is clicky and that it isn't too expensive as well.
Would love to hear your suggestions about this.
Thank you in advance, and most likely i will be ordering through amazon.
No-one can suggest a KB to you, since it's personal choice and defined by your individual taste and feel.
Best we can do, is give ballpark options, e.g like this roundup,
article: https://www.rtings.com/keyboard/reviews/best/by-type/wireless
Btw, "clicky" KB is most likely due to the Blue switches it has. E.g Cherry MX Blue switches will produce audible click every time key press is registered. Clicky KBs are usually suggested for typist/writers. Unless you're talking about tactile bump when pressing the key down. If so, then Cherry MX Brown is the one with tactile bump.
As of why no-one can suggest KB for you to go for, here's a nice example based on what i use;
Currently, i'm using Corsair Strafe RGB with Cherry MX Silent switches. It is full size and wired, just like i prefer it. And my latest KB purchase (to replace my Strafe RGB out) is Corsair K100 RGB with OPX switches, which is way out of your budget + then some. Also K100 RGB is also full sized and wired KB.
