• Now's your chance win big! Join our community and get entered to win a RTX 2060 GPU, plus more! Join here.
    Pi Cast Episode 3 streams live on Tuesday, August 4th at 2:30 pm ET (7:30 PM BST). Watch live right here!
    Catch Scharon on the Tom's Hardware Show live on Thursday, August 6th at 2:00 pm ET (7:00 PM BST). Click here!
Question Suggestions for CPU cooler,Case cooling and Case fans
Aug 14, 2019
13
I have a Ryzen 5 1600 paired with RX570. I plan to overclock my processor to 4ghz. What cooler would you guys suggest? My budget is upto 70$. Can Hyper 212 evo cool my processor?
Now about the case case fans..I have a Cooler Master MB511. The front panel can fit 3x120mm fans OR 2x140mm. Which ones should i go with? The top panel can be mounted with 2x120mm or 2x140mm so for the top i'm gonna go with 2x140mm...but what about front panel..? Which one's gonna provide better cooling (3x120mm or 2x140mm)?
About case fans would you guys suggest Ring LED fans or normal RGB fans [Fan which blades glow] for better look? I'm also open to all case fans suggestions.
If you guys can't understand the above here are my questions
  1. Best CPU cooler for Ryzen 5 1600 under 70$
  2. 3x120mm or 2x140mm front panel case fans for intake
  3. Ring LED case fans or Normal ones[Fans which blades glow] for better look/brightness/glow in case
  4. RGB budget case fans suggestions [RED]
