Suitable motherboard for i3 7100
hafeez0198
4
Hi as I have a cpu which contains AMD quad core 4100 processor with gigabyte mother board ,with 1 TB hard disk and with 4 GB dynet ddr3 ram.which always giving trouble and not working properly now mother board got bois setting problem.which is under repair.. .so finally I decided to take new assembled cpu..which I taking intel core i3 7th generation processor...for this processor I want suitable mother board,Suitable rams,Suitable hard disk,suitable graphic card, and suitable smps..which this all I want to fix in professional circle cabinet..so please help me in finding suitable accessories.
https://www.xtremegaminerd.com/build-a-300-beginner-gaming-pc/
These are pretty much the standard components when trying build a PC on a budget. I don't believe this factors Windows OS.
So you have a processor but need MoBo, RAM, GPU, and Power Supply. What do you want to use the PC for? You can always use PCpartpicker.com and build a PC. It will let you add your processor and then give you compatible parts to go with it.
Hi well I didn't yet purchased processor..i said I m planning to purchase. And my budget I can spent is 25,000 Indian rupees ..in this 25,000 rupees I want a assembled desktop CPU..So tell me which processor is best and if any processor is best then when motherboard suits .and about rams,graphic card, spms, operating system , hard disk , each and evrythng..regarding CPU..so finally my budget I can spent is 25,000 Indian rupees to 30,000 ..i want for gaming mainly and for home use only..so tell suggest me a assembled cpu with good brand accessories
