Ok, so thanks to other responses recently I have been able to determine wat two graphics cards I can likely use. Will either of these be usable with my current system? I would like to just upgrade my current graphics card that came with my system.
Processor 3.6 GHz FX-Series Quad-Core FX-4100
RAM 8 GB DDR3
Hard Drive 1024 GB SATA III
Graphics Coprocessor NVIDIA GT610
Graphics Card Ram Size 1024 MB
Number of USB 2.0 Ports 6
Windows 7 Home Premium 64-bit
Computer Memory Type DDR3 SDRAM
Hard Drive Interface Serial ATA-600
Hard Drive Rotational Speed 7200 RPM
Optical Drive Type 24x DVD±RW
PSU: Turbolink ATX-TL500W-BK
I was suggested either the AMD 7750 or 7770, will either of these work? Is my PSU capable of handling this? Will my PSU even have the plusg to allow this? I do not want to have to do all the cable management, thats why it was bought prebuilt.
Does anyone know if upgrading to one of the two cards will be possible with my current PSU? Or if I need any additional things to make the upgrade work?
RAM 8 GB DDR3
