Solution Ralston18 Jul 31, 2018 Check the website: https://support.ubi.com/en-US/Faqs/000017684/Minimum-Requirements-PC-SC6 Windows 10 does not seem to be explicitly listed. What is "not said" is sometimes just as meaningful as what is said. So the answer may be no. However, look through the various pages to see if there is some confirmation one way or another. Or perhaps some workaround via an appropriate emulator within Windows 10.
Ralston18 Titan Moderator Oct 11, 2014 39,378 4,364 146,290 Jul 31, 2018 Solution #2 Check the website: https://support.ubi.com/en-US/Faqs/000017684/Minimum-Requirements-PC-SC6 Windows 10 does not seem to be explicitly listed. What is "not said" is sometimes just as meaningful as what is said. So the answer may be no. However, look through the various pages to see if there is some confirmation one way or another. Or perhaps some workaround via an appropriate emulator within Windows 10. Upvote 0 Downvote Solution
