So not even sure how to ask or explain it so ill say everything
last night i woke up around 10pm and the day before was splendid everything working fine
well when i woke up i decided to play some games and such, finally i decide to web browse and enjoy memes and such but every time i do click on any website like facebook, sometimes google, almost any site doesnt seem to have a pattern these things happen
- redirects me to a security check from google i just clicked out of it usually, but it comes right back and its facebook so i click im not a robot, go through a captcha process everything is hunky dory later it happens again, and again... and again. :| now its getting on my nerves at the bottom of this security thing it suggests 3 options run an antivirus, and malware checker, to prevent seeing this page, it also suggests me to if not on home network tell someone higher up to scan the whole everything is how i took it, it also suggest an extension to bypass it, well its obviously a problem i do not want to just sweep it under the rug i might trip over the bump later
so i scan my computer have done so 3 - 4 times now nothing shows up cleared registries and cookies ect, so it didnt take the cake i checked my roommates seeing what their up to see if they are using a program of any sort because looking into it vpns can cause this only one of them are even home and her stuff isnt even on
so now im getting worried whats happening i check my router logs
heres what i find
-one iphone spamming the router with a DHCP IP (dont think this is the problem i can disable it and check but i doubt it)
-heres the creepy bit
-a mass occurrence of Wlan Access rejection, due to incorrect security this is not by one device tho ive written down the mac address attempting connection so far i have 3 and most of the tries are attempts with the spam of 3 seconds and some with 10 seconds apart
so it doesnt stop there
- ive also was wondering where my device is on the attached devices because im seeing if these failed attempts succeeded yet or if theres any new devices i dont recognize
-nope but i dont see mine, well i thought i didnt my computer name and connected ip doesnt exist on it but my mac address does i personally assigned my ip so i could recognize it and sure i thought maybe i was mistaken and then i checked with cmd it hasnt changed nothing has but i barely exist on it so to speak
ive also noticed other things like, when i open teamspeak it tells me i cant connect to its services, but when i go to join something i can connect :/ what?
and other things weird like when browsing memes my whole tab starts glitching black and weird but that hasnt happened more than once i think it was do to my ram getting overloaded i forgot to turn of my game i think it had a ram leak or something hasnt happened since so i have no idea whats going on or what i should do to fix it
at this point should i reboot? is it safe to do so not sure if its a dumb question but if my ip isnt assigned to me then is it assigned to another dont know the odds not (IP but the router ip 192 one)
should i change my router ip? and mac address?
should i not be worrying at all?
what risks and probabilities are even this?
and most of all is there a fix its not just my computer its other devices i own
heres what i find
