nukemaster
none12345 :
"I have to wonder if you can use both sides of the panel(double breaker) to get 240 volts(same way the stove and electric dryer or furnace do). This would reduce the current requirement(get you under 10 amps) so 14 gauge will handle it without issues again. You would clearly need a 240 volt plug to prevent issues like plugging something else into this 240 volt outlet."
Yes you can. You can tap either leg to ground for 110-120 or you can tap leg to leg for 220-240. But you wouldn't just want to rewire an existing breaker in your panel. Technically speaking, its possible, assuming proper wiring, but its not smart. In the best case, this would violate electical codes. In the worst cast, you die. Next worst case, assuming inpropering wiring of your house, or you dont do it correctly, and you could fry lots of shit. Violating electrical codes would be an issue if you wanted to sell your house, and be an issue with insurance...
The way to do it is to add a new breaker on 240, and run a dedicated line to a proper 240v outlet. 240 is a lot more dangerous then 120. Call an electrician unless you know what you are doing.
It is more the lack or a "neutral" that makes me wonder.
I mean its X and Y hot(120 per side) and your normal ground. I do not even know if computer power supplies are polarity sensitive.
Its not exactly hard to use a double breaker(pick the right amp rating) for this and the same 14/2 that runs in most houses is also good for 240 volts. You can get power tools that use 240 volts and you have to wire a plug in accordingly for those as well.
