SUPER loud PC help!
Jaredb1
Commendable
Mar 7, 2016
130
My PC is incredibly loud when under load. It sounds like a jet taking off!
I have a video clip of it running under load (I was either playing something or rendering by i forget which).
It has a FX-6300 with a GTX 960 (EVGA SSC 2gb) stock AMD heat sink and whatever rear case fan was with the case, and I replaced the two front fans with rosewill 120mm fans. The case is a thermaltake versa H22 window.
Please identify the problem and provide some solutions (this is my first build so I'm kind of a newb)
Yes the window is broken, this happened in shipping and I am trying to get it replaced.
Video clip:
http://www.youtube.com/watch?v=ba7f_9M2Hm0
I can almost confirm that the AMD heat sink is the main(might not be the only) culprit.
If you don't plan to OC get an aftermarket one like beQuiet! Dark Rock 3
Rule of a thumb, the smaller the fan, usually the noisier they are...
I'm definitely over clocking at some point.
