I just built a new system and have been doing some tweaking and testing to check if my airflow is in check, and if I may possibly have some overclocking headroom.
First thing I did was undervolt the CPU to see how that affects temperatures (I am working towards silence at the moment). To my surprise, using the offset in bios, my Core Voltage is fluctuating as low as 0,624 according to CPU-Z (usually under stress test 1,216, maximum of 1,312). That seems really really low, but running stress tests such as AIDA64 and Prime95 have been absolutely stable. But can such a low reading actually be correct? CPU-Z and Aida64 both show the same figures. I have no MCE enabled, only XMP.
AIDA64 FPU test gave me a max temp of 84, which I am relatively satisfied with considering my cooler isn't high-end. Will invest later when I overclock. I'm not comfortable installing a super-heavy heatsink, as I move my system to lans regularly.
System specs:
i7 8700k
Thermaltake True Spirit 140 Direct
Asrock Z370 Extreme4
16gb (2x8gb) G.Skill Ripjaws V 3200mhz CL16 DDR4
GTX 970 (2080 Ti is preordered)
NZXT H500 (2 intake fans + 2 exhaust fans)
System specs:
i7 8700k
