Super Low Unigine Heaven Benchmark Score! What's my issue?
TaylorEG
6
What could be my problem? Any and all help is VERY much appreciated. Seriously have no idea what the issue could be... and yes I know there are many similar posts to this one, but my score is around a thousand lower than those posts who think their score is low. Please let me know if you need more information as well. I'm not very adept at what information is needed to come to a conclusion as to why this issue has arisen.
Unigine Heaven Benchmark 4.0
FPS: 60.9
Score: 1534
Min FPS: 7.3
Max FPS: 129.4
Settings:
Render: Direct3D11
Mode: 1920x1200 Resolution
Preset: Custom (It says custom but i just downloaded it and ran with all default settings)
Quality: High
Tessellation: Disabled
CPU Performance Benchmark:
Geekbench 4: https://browser.geekbench.com/v4/cpu/5623534
(Will comment soon, currently downloading Geekbench 4 and PCMark 8)
SSD Performance Benchmark (via Samsung Magician):
Sequential (MB/s):
Read: 339
Write: 512
Random (IOPS):
Read: 34,276
Write: 26,912
System:
CPU: Intel Core i7-4790 3.6 GHz Quad-Core Processor
MoBo: Asus Z97-A ATX LGA1150
Memory: Crucial Ballistix Sport 16GB (4 x 4GB) DDR3-1600 Memory
Storage: Samsung 850 EVO-Series 1TB SSD
GPU: Asus GeForce GTX 1070 8GB Video Card
OS: Windows 7 Home Premium x64
Additional Build Components:
CPU Cooler: Corsair H80i 77.0 CFM Liquid CPU Cooler
Power Supply: EVGA SuperNova P2 750W 80+ Platinum
Your temps look OK. It seems the CPU is running at far lower performance for some reason. A bench test like Cinebench can zero in on the CPU and confirm this.
Is your PC set to maximum performance in Windows power options? Windows key + change power savings settings
Are there any power savings features enabled in your BIOS settings? Hit CTRL+ALT+DEL to get into the settings. Look for things like power saving or EZ system tuning.
Switched BIOS to Optimal instead of Normal and changed Win7 power settings from Balanced to High Performance.
Also, stopped my startup programs (samsung magician and f.lux) and this is the new cpu score:
https://browser.geekbench.com/v4/cpu/5628433
So one of those things was REALLY slowing down my CPU. I'll test Heaven again and see if that score improves then retest with the bringing back all the settings I changed to see which one had the biggest effect.
Thank you! Thank you! Thank you! You are a God send. This is my new score:
FPS: 179.7
Score: 4527
Min FPS: 35.2
Max FPS: 347.2
I have a meeting to go to. I'll figure out exactly what the issue was and update tomorrow. Seriously though, I was freaking out thinking my new card was faulty. So thanks again for the help!
