Question Supermicro X8SIL-F booting problem
Oct 20, 2019
Hi. I have specific problem in very specific hardware. I hope that someone will help me.
I have:
motherboard Supermicro X8SIL-F with chipset Intel 3400,
procesor Xeon,
NVIDIA Quadro600 GPU.
GPU have 2 outputs: display port and DVI.
Problem is - when I turn on the comp and it's booting, BIOS beep code IS beeping and booting doesn't finished already. I have to disconnect both cables from GPU (have to be both cables, one isn't enough). Then plug in reduction DVI-VGA into DVI port (only reduction without any cable needed). And turn on the comp again.
BIOS beep there times and PC is booting without problems. After that I can plug out the reduction and insert cables from monitors (I have 2 the same monitors) into GPU. And everything is ok and works.
Where is problem????
I tried different cables, dual link too... But still the same problem.
Many thanks for help.
