It is fine to leave the I utilized piece hanging in the air.
It is intended to plug into a second card if you want to run it in SLI mode.
You can employ some cable management and try to keep it from coming in contact with anything. But it can just hang in mid-air too.
As long as both the 6 and 8 pin connectors are plugged into the card, you are good.
