SURFACE PRO 3 KEYBOARD HELP A.S.A.P please
Bad bear
20
the yuiop keys on my surface pro 3 does not work and is anoying the hell out of me.
does some one have a solution
thanks.
Try this...
1. Uninstall the keyboard driver.
2. Reboot the computer (without reinstalling the driver).
3. When it restarts, it should reinstall the driver on its own.
If this doesn't work, you may wish to try connecting an external keyboard and see if it works fine. If it does, then it could be the keys themselves that are the issue.
You may also want to try updating the Synaptics Driver if the above doesn't help.
Try this...
