Surface Pro With 4K TV As Monitor -- What Will the TV's Display Resolution Be?
phsiao1214
7
Hi Everyone,
I'm considering the Surface Pro (2736x1824) with my Sony X720E 4K TV (3840x2160). I'd like to know what resolution the 4K TV will output?
Right now, I have a Huawei Matebook X pro (3000x2000) that outputs to a 27" 1080p monitor, and the scaling is totally off. Wondering if I would also encounter this with the Surface Pro + Sony X720E TV setup?
Thank you
You can set the video resolution to TV according to the TV native resolution.
If the X720E TV is native on 4k, set it to 4k.
If your monitor is 1080p, set it t0 1080p.
Manually!
i got a surface book 2 with a MS HDMI adaptor which outputs 4k res. However when connecting to a 4k Sony tv (2015) it displays it but its stretched slightly and i have googled this and tried to find settings via tv but nothing which solves this. If I scale the SB to 300% then it shows everything! anyone seen this issue before? or have you connected a SB2 to a 4k TV?
