I live in Europe and i'm thinking of buying this surge protector from APC here http://www.apc.com/shop/gr/en/products/APC-Essential-SurgeArrest-8-outlets-230V-Germany/P-PM8-GR , the surge protector seems really good but there are few things that bothers me.
1) if you scroll a little bit down and go at the "Technical Specifications" there's it's specs and it says "Nominal input Voltage : 230V" and some lines down it says "Input power of 2300.0 Watts" the question is whats the deal with the *input power of 2300Watts*? That means that the surge protector is drawing 2300Watts to work or something or it is it's max power that can handle if i put on it my desktop,router,screen and many more electrical devices? Because you know if it needs 2300W to only work this guy plus the components that i plug onto it my bill will skyrocket.
2)What's the nominal input of 230V?
3)And lastly how much power the surge protector will draw from the wall? It will draw as much as the components on it needs?
Thanks guys.
Thanks guys.
