Surprise: PowerColor Makes A Sound Card, And It Sounds Good
Even with the newer nicer onboard audio chips, a discrete card will always be better. I have a Asus Maximus VI Formula and the onboard audio is good but my Creative SB-Z is just better by far. Better sound quality, can be louder and more control.
just Analog if you send out a digital signal what ever takes that is going to do most of the work (receiver or DAC for head phones or that fiber jack). but you can most of the time with sound card software change like the eq and what not. but better quality it wont don any thing for that
I love audio marketing. Sometimes I think that the same folks that do the media for political campaigns also do the ads in audio magazines and that sort of thing. Looking at the diagram, there are some silly things (of course), but the actual implementation looks about as good as you need to get for a sound card.
- Nichicon MUSE caps...OK. Powercolor must have meant DE-coupling caps, because these are just the bulk filtering caps on the power input, and over at the LDO regulators. On that point, it is good that they used LDO's rather than switching regs because switchers make a LOT of EMI (and are generally more costly). Anyway, given the frequencies of the transients involved in a PC, these bulk caps are only a piece of the noise-reducing puzzle. Quality ceramic or tantalum SMD caps are crucial to taking out high frequency noise from the power supply, and I do not see much in that respect.
- Molex Power Connection...BS. Supply ripple is going to be present on all of the 12V rails. I find it doubtful that the voltage supply on the PSU's Molex plugs is really much cleaner than that of the PCIe supply. Besides, that's what all those bypass caps are for.
- Daughterboard extension...OK. Note that the daughterboard gets its signal from the Cmedia DSP chip's onboard DACs, not the nice Wolfson DAC. So, ONLY the main stereo outputs will have the "hi-fi" audio signal. There is also another QFP IC to the right of the Cmedia chip, which might be the multi-channel DAC for the daughterboard. Either way, Powercolor did not bother to point that out, so it is probably one of the same chipsets that you would find in an onboard audio subsystem.
- Cmedia CM8888...OK. This is the real meat and potatoes of the sound card, and it's a commodity IC. The multi-channel audio outputs for the daughterboard either come from this, or the smaller QFP chip to its right.
- DAC...GOOD. The Wolfson WM8741 is a legit hi-fi DAC. Not much more to say there.
- TI LM4562...GOOD. These opamps have been on the market for about a decade. They are regarded as being good parts by the DIYAudio community (although arguing over opamps can basically be a religious war over there!). Anyway, not much to say here either. They are good performers for a relatively low price point. You could spend a LOT more on opamps with better specs, but the law of diminishing returns would set in really fast.
- Gold plated outputs...OK. Gold won't corrode, that's about the only real reason to care.
- Swappable opamps...BS. The opamps in there are fine. A few people may be on the "argue to the death about the best opamp" list and actually go do it, but there is no need to.
- Polypropylene caps...GOOD. The opamps are most likely configured as low-pass filters for signal content 20kHz and below, and for filter applications, poly caps are one of the types that are correct for the application. C0G/NP0 ceramics are also fine, and a lot smaller, but from a marketing standpoint the poly ones are probably a better choice since there is a general notion that all ceramic caps are bad for audio (and it's true, except for C0G/NP0).
So, this thing looks like a reference implementation of the digital / multichannel side, and they added some above-average analog bits for quality stereo listening. Is it worth $159? Maybe. While the implementation is good, the fact is that this thing is still inside the PC chassis where you will have a fair amount of EMI blasting around from high-speed high-current transients due to the CPU, GPU, RAM, etc. It might be better than an external USB DAC though, since those are limited to a noisy 5V supply (unless it requires a wall-wart with 12V output), and you would need a switching boost regulator to get high enough voltages to drive headphones adequately. Overall, I think that this would be better than a USP-powered external DAC, but not as good as an external USB DAC with its own 12V-20V power input.
Also, anyone that is going to bother with a nice sound card should take a look at the their audio source material. Lossy compressed files like MP3s and whatever most games used these days are going to introduce plenty of distortion from the compression algorithm. To really take advantage of nice analog hardware, you need to go with FLAC audio ripped directly from a CD.
Question. Sounds cards are great but nowadays many people including myself use audio via HDMI (output from video card). Is there any way to "inject" the audio output from the sound card to an audio input on the graphics card? This way the HDMI cable is delivering the best graphics and audio from separate dedicated cards.
There would not be any advantage to doing that, actually. Think about the audio signal and where it starts/ends. The signal begins with a digital file on your computer (over the web, whatever). Ultimately it will be converted to an analog signal which is amplified and sent to speakers or headphones. Every time a signal is converted between digital and analog (or analog to digital), noise and distortion are introduced.
So, the sound card converts the digital signal to an analog one. To put that signal back into the HDMI audio stream, you would need to convert it back to digital. Once it is sent over HDMI, it is converted to analog once again on the other end. That adds lots of unnecessary conversions which lower the signal's quality.
If you are using HDMI audio output, you want to do this: keep the signal digital all the way until the very last point in the chain when it is converted to analog for speakers or headphones. You have a couple of options.
1) If the HDMI signal goes to a device with digital pass-through (many TVs will allow you to take HDMI audio input and output stereo audio --- NOT surround --- via SPDIF or TOSLINK), you can take the digital audio output of that device and just connect it to a DAC. Note that many TVs only output audio at maximum volume, so you would need to control the volume with your PC or the amplifier that gets the analog signal. Here is the device that I use for that purpose:
http://www.amazon.com/gp/product/B00F4ORTZ6
2) You can get HDMI audio DACs. These devices are placed between the PC and TV, and will extract the audio signal from the data stream and convert it to analog. In my opinion, this might be the best option for you...keep the signal digital all the way out and away from the PC! The type of device I mean is something like this (I have not used this particular one):
http://www.amazon.com/ViewHD-Premium-Extractor-Converter-VHD-H2HSAs/dp/B00KBHX072/
I like it, but not for the price. All I care about is analog stereo, so if they could cut the rest and just give me the two rca out at 124db snr for about half the price, I'd buy it yesterday. Doesn't need a headphone amp, doesn't need optical out, I assume those op amps are for the headphone amp so it doesn't need them, as someone said better power filtering and dump the molex...
12V DACs are [pretty expensive Schiit.](http://schiit.com/products/bifrost-b-stockblack)
1) My Auzentech X-Fi Forte still sounds a LOT better than the latest Realtek solutions to me using high quality speakers or headphones.
Tek Syndicate claimed dedicated sound cards were pointless but my testing contradicts that completely. I also did blind tests with other people to confirm.
2) DIGITAL OUTPUT:
If you're only using the digital output it is arguable that you are wasting your money. The main advantage for dedicated sound cards is to reduce noise from PC and do better shaping (via OP-AMP) of the analog signal.
Digital outputs are still turned into analog but done so in the speakers (or certain headphones that use an external DAC).
When you sound out the digital signal it's the SAME for onboard audio as for dedicated unless you're using some post-processing feature to alter the intended sound solution the game or music had.
3) $50 vs $170 sound card??
Hard to say. I suspect there's a point at which there's little benefit to most people assuming a quality $50 sound card. Unfortunately there's a lot of subjective analysis and little proper objective diagnostic testing to properly compare sound solutions.
4) Post-processing of audio:
Be very careful about allowing software to process your audio. I turn all these feature OFF. Some "enhance" the music or game audio supposedly but to me it just makes things worse.
5) 2D vs 3D:
One thing I'm very interested in is proper 3D on 2D headphones. multiple speakers (drivers) in headphones don't seem to work well to create 3D however a real-time hardware method to turn SURROUND sound into VIRTUAL 2D sound would be awesome. I know Asus has a motherboard that offers this but can't test. I'd love to see this on a proper dedicated sound card like this Power Color model.
I don't blame you guys for getting your headphones out, I would certainly have to hear it myself to believe it's better than the Purity Sound II on an AsRock board, especially considering they use almost identical components, don't require expansion bays, PCI-e, or $150.
As some have pointed out, if you are using a digital audio output from the PC and sending that to a receiver, then there is NO point in using anything besides the onboard audio subsystem since you are keeping the audio signal in digital form all the way out. Digital is digital, and your nice big AV receiver IS the DAC, so whatever components are inside of that will determine the analog signal quality. To be honest, any decent AV receiver is probably going to have parts in it that are at LEAST as good as you will find on a PC sound card, and I would wager that it probably has better ones.
Will dedicated sound cards sound better than the onboard audio outputs present on the motherboard? Yes, probably. Most onboard audio subsystems just use the DACs that are built into the chipsets, which probably have OK specifications, but since space is tight on many motherboards these days, power supply bypassing and decent opamp gain stages for the outputs are probably minimal or not present. A dedicated card is a PCB with space dedicated to audio, so it will probably have much better power supply decoupling and output gain stages. I have not looked closely at the onboard audio layout on a PC motherboard in a long time, but I would guess that these days, the DSP chips are powered by the same 3.3V rail as all the other high frequency stuff, and with minimal power supply bypassing, some of this power supply noise will make its way into the DACs (and hence the analog audio signal). Any decent dedicated sound card will be powered by the 12V rail and then have some LDO Vregs of its own to drop the voltage and prevent a LOT of power supply noise from ever reaching its DSP / DAC chip(s).
Sound card looks decent. I like the shielding on the Asus Essence ST better though. If I were going to buy a new PCI based solution, would probably go with the Essence St version 2 that was just released. The original, paired with Beyerdynamics DT 990 Pro = easily the best sound I've ever heard from a computer. Unfortunately I can no longer use it because my two 970 GPU take up too much room on my MOBO, So I need to sell it or find someone to trade for an external Dac/Heaphone amp.
Thanks for the review but PowerColor didn't make this they just stamped there name on a SC808 ( 7.1 PCI-e HD Audio Card) . Which came out2014 and over seas sold for about $115 US
