Surround Sound Gaming Headsets, Logitech G35 & AX Pros
barret50cal
61
Hi guys, so with all things considered, which headset is better, the Logitech G35 or the Tritton AX Pros? I've read reviews of both, and they are very mixed. People say that the Trittons break after the first few months of good use, is this true? and the G35s I've heard can get uncomfortable. I've heard mixed reviews about the audio on both too, and feel free to suggest other headsets that you might think are better.
Basically this is what I want to know:
Are the Logitech G35s uncomfortable after a while?
Which headset sounds better?
Is the Stereo mode on the G35s better than the surround mode?
Will the Trittons break after a couple of months of regular use?
Any other useful info is appreciated.
Thanks!
I'd suggest a Creative Labs Sound Blaster Arena, or Sennheiser HD555's for general use. If you can't get any of these then go ahead with the Logitech G35's. Not sure if any of this helps but you could look into the headphones I suggested.
