svchost.exe network services problem
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Everytime I connect to the internet, any application I start which uses the
connection doesn't work or is really slowed down util I end 'svchost.exe
network services in task manager' How do I fix this? I 'm running windows xp
service pack 2 with a broadband dsl connection. Thanks!
Hi,
Open Windows Explorer to this folder:
C:\Windows\system32\wins
Is there an svchost.exe file here? If so, you have a virus.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Associate Expert - WindowsXP Expert Zone
www.microsoft.com/windowsxp/expertzone
Windows help - www.rickrogers.org
"Confused and Befrazzled" <Confused and
Befrazzled@discussions.microsoft.com> wrote in message
news:A10F1743-4976-4958-B4D6-D8E22EA629B1@microsoft.com...
> the
> xp
nope theres no svchost.exe in there ,hidden or normal
"Rick "Nutcase" Rogers" wrote:
> Hi,
> Best of Luck,
> > the
> > xp
Hi,
Start/run cmd, type tasklist /svc
Post back with what is running in the various svchost.exe listings.
Best of Luck,
"Confused and Befrazzled" <ConfusedandBefrazzled@discussions.microsoft.com>
wrote in message news:3BBF8936-6517-472D-9FB3-997B69EE5C1D@microsoft.com...
>> Hi,
>> Best of Luck,
>> > the
>> > 'svchost.exe
>> > windows
>> > xp
I'm using home edition but I managed to get the listings
These Windows services are started:
Application Layer Gateway Service
Ati HotKey Poller
Automatic Updates
COM+ Event System
Computer Browser
Creative Service for CDROM Access
Cryptographic Services
DCOM Server Process Launcher
DHCP Client
Distributed Link Tracking Client
DNS Client
Error Reporting Service
Event Log
Fast User Switching Compatibility
Help and Support
HTTP SSL
Iomega Active Disk
Iomega App Services
IPSEC Services
Network Connections
Network Location Awareness (NLA)
Norton AntiVirus Auto-Protect Service
Norton AntiVirus Firewall Monitor Service
Plug and Play
Print Spooler
Protected Storage
Remote Access Auto Connection Manager
Remote Access Connection Manager
Remote Procedure Call (RPC)
Secondary Logon
Security Accounts Manager
Security Center
Server
Shell Hardware Detection
SSDP Discovery Service
Symantec Core LC
Symantec Event Manager
Symantec Network Drivers Service
Symantec Settings Manager
Symantec SPBBCSvc
System Event Notification
System Restore Service
Task Scheduler
TCP/IP NetBIOS Helper
Telephony
Terminal Services
Themes
Universal Plug and Play Device Host
WebClient
Windows Audio
Windows Firewall/Internet Connection Sharing (ICS)
Windows Image Acquisition (WIA)
Windows Management Instrumentation
Windows Time
Windows User Mode Driver Framework
Wireless Zero Configuration
WMDM PMSP Service
Workstation
The command completed successfully.
> Hi,
> Best of Luck,
> >> Hi,
> >> Best of Luck,
> >> > the
> >> > 'svchost.exe
> >> > windows
> >> > xp
Hi,
We need the results from the /svc parameter, as it shows what services are
using the svchost.exe file.
Best of Luck,
"Confused and befrazzled" <Confused and
befrazzled@discussions.microsoft.com> wrote in message
news:7B8218DB-7FDA-44D8-9AA5-439FDA66F1B1@microsoft.com...
> Ati HotKey Poller
> Automatic Updates
> COM+ Event System
> Computer Browser
> DHCP Client
> DNS Client
> Event Log
> Help and Support
> HTTP SSL
> Iomega Active Disk
> Iomega App Services
> IPSEC Services
> Network Connections
> Plug and Play
> Print Spooler
> Protected Storage
> Secondary Logon
> Security Center
> Server
> Symantec Core LC
> Symantec SPBBCSvc
> Task Scheduler
> Telephony
> Terminal Services
> Themes
> WebClient
> Windows Audio
> Windows Time
> WMDM PMSP Service
> Workstation
>> Hi,
>> Best of Luck,
>> wrote in message
>> >> Hi,
>> >> Best of Luck,
>> >> > uses
>> >> > the
>> >> > 'svchost.exe
>> >> > windows
>> >> > xp
i'm not sure what command to use since home doesn't support the one you put
up but the services using svc host from the task manager are:
system(4),network service(1),local service(1)
> Hi,
> Best of Luck,
> > Ati HotKey Poller
> > Automatic Updates
> > COM+ Event System
> > Computer Browser
> > DHCP Client
> > DNS Client
> > Event Log
> > Help and Support
> > HTTP SSL
> > Iomega Active Disk
> > Iomega App Services
> > IPSEC Services
> > Network Connections
> > Plug and Play
> > Print Spooler
> > Protected Storage
> > Secondary Logon
> > Security Center
> > Server
> > Symantec Core LC
> > Symantec SPBBCSvc
> > Task Scheduler
> > Telephony
> > Terminal Services
> > Themes
> > WebClient
> > Windows Audio
> > Windows Time
> > WMDM PMSP Service
> > Workstation
> >> Hi,
> >> Best of Luck,
> >> wrote in message
> >> >> Hi,
> >> >> Best of Luck,
> >> >> > uses
> >> >> > the
> >> >> > 'svchost.exe
> >> >> > windows
> >> >> > xp
