E Erkan Oct 26, 2019 6 0 10 Oct 27, 2019 #1 I am going to buy a pre-built computer but i want to change the case (https://bytdator.se/begagnade-dator...6300-i5-3470-8-120SSD-500-GTX-1650-4GB-W10-A2 ) what case could i use and is it possible. BTW it has a q75 motherboard.
popatim Titan Moderator Dec 2, 2009 39,136 1,041 136,890 Oct 27, 2019 #2 Nope, won't fit. It uses a BTX style if images on google are correct. Upvote 0 Downvote
E Erkan Oct 26, 2019 6 0 10 Oct 28, 2019 #3 do you know what motherboard that will fit an atx case or mini itx case with the i5 3470 and ddr3 ram Upvote 0 Downvote
Spaceghaze Reputable Oct 17, 2019 212 21 4,615 Oct 28, 2019 #4 Make sure that you dont break the warranty by changing the case though. Upvote 0 Downvote
